No aluminum wires used, although I have no idea what 'erc' is.Will it solder ti the aluminium erc power wires
Copper is easy, much easier than aluminum. How many amps you planning to be pulling on this?The esc, the esc has aluminum power cables thou.
Not they don't.the esc has aluminum power cables thou
I don't know... a 3s?Copper is easy, much easier than aluminum. How many amps you planning to be pulling on this?
3S, what size, what motors and battery.I don't know... a 3s?
12 gauge should be fine, but bigger would certainly not hurt on your trunk line. If you have nothing else just pair two wires in parallel. .I haven't got a battery yet.. I have 12 amp esc. And 2300 kv motors..
Mine do hahahahaha.Not they don't.
You ESCs come with aluminum wire? Post a LINK.Mine do hahahahaha.
It is not all that uncommon, most of your batteries have Al leads. Aluminium is 200% more efficient looking at load vs weight. I'm doing something right now but I'll post a link or some links.You ESCs come with aluminum wire? Post a LINK.
As long as you're not including alloys, then the list gets much larger.Actually, aluminum is 4th, following only silver, copper and gold
