Won't arm, green flashing light, wizard x220.
sconehead
Hi everyone i'm new to this forum need some help please.I've got a wizard x220 and it won't arm its bound to tx and there is a green flashing light on the fc board which is a naze 32.Its driving me crazy please someone help me before i take a hammer to it hahaha kidding. o_O
Green light means your receiver isn't talking to the FC. When set up correctly, you should have no LED, then solid blue when armed. What software are you using to set it up?
If it's set up properly you should have:
In ports tab, enable enable serialrx for uart2
In configuration tab, enable serialrx as provder
In receiver port, click sbus button to enable
Let us know if this works
No still got the green flashing light now there is a red light (solid) next to the green one.
Sounds like you're getting closer. In configuration tab set mincommand to 1000, minthrottle to 1070 and maxthrottle to 2000. Also, a closeup pic of your receiver and connection the Naze would help. are you arming by stick or switch?
