VFAS voltage on OSD but not on Taranis
texasgrape
Although the Taranis QX7S is showing all the telemetry it should the VFAS shows only dashes for the voltage; However the OSD shows the correct voltage; RSSI; TX batt; all working but when I go to the Telemetry on the Taranis page it shows "---" for the voltage; evidently I have something set up wrong; any help would be appreciated! Thanks!
SOLVED: There are two VFAS' in some Taranis'--the correct one was way at the bottom of all the telemetry listings which showed the correct voltage--I deleted the incorrect one
