Stormyj
Hi all.
Well, it had to happen eventually. Fly away of my 550mm quad and ended up in a tree, about 75 ft up. Came back a day or so later to try and get it down, and it fell out by itself, 75ft and hit hard ground. Dug one arm into the dirt, broke off the tip of arm and damaged a motor., along with other things, gps, props. That was about all I could see. So ordered new parts and rebuilt. Changed 9" props to 10" slow fly both are 4.5 pitch. Changed one bad motor, the one embedded in the ground. Calibrated escs. On my first flight just to test it out, I used my 3s 2200 lipo. It is light. Seemed a bit squirrly, but chocked it up to me being a bit nervous. The next day, I put the 4s 4000 lipo and it was dancing all over the place. Tried a 5800 lipo and again, danced around like crazy. It responds fine and goes where I tell it, but it seems a bit crazy. Anyone know what might be going on. I have uploaded a few videos of it in flight with the different batteries. Any help would be greatly appreciated. bty, the gps is not connected because it was damaged also, might that be causing it? Thanks guys. if you have any questions please ask. Also attached a few pics of damage.
Video
Pictures
https://www.facebook.com/photo.php?fbid=1316249928385945&set=pcb.1316250421719229&type=3&theater
https://www.facebook.com/photo.php?fbid=1316250135052591&set=pcb.1316250421719229&type=3&theater
https://www.facebook.com/photo.php?fbid=1316250321719239&set=pcb.1316250421719229&type=3&theater
Video
