Trouble getting telemetry working on clracingf4s
bulldogc
Hi folks, I am nearing completion on my first build and I am having some troubles getting my telemetry enabled/tested. I am using a cl racing f4s with Makerfire BLHeli_32 32Bit ESCs (link below). I wired all 4 of my tx pads from the ESC to the telem pad on the f4s but when I try and enable the ports in betaflight it just resets after reboot. So far I have tried,in various combinations, setting uart3 to smartport and setting sensor input to ESC. The only setting that sticks is if I enable ESC by itself, everything else is reset on reboot. Can anyone offer up any help? If it matters I had to twist/solder the 4 wires together with a 5th that I wired to the pad, couldn't get the other 4 on the pad without doing this, I did verify continuity between each of the 4 pads however.
Additionally I am running with a 4cell bettery, but when I plug it in betaflight detects it as a 3 cell battery, how can I correct this?
Finally, my ESC is suppose to support up to DSHOT1200 but for some reason I am only able to select up to 600.
esc- https://www.amazon.com/gp/product/B07K76TGTR/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
battery- https://www.amazon.com/gp/product/B07Y15GY7C/ref=ppx_yo_dt_b_asin_title_o07_s03?ie=UTF8&psc=1
