Spring Practice Rippppp!!!
Nice run! The track cruising is definitely cool looking makes me want to find some abandoned tracks around here to go cruise too. Think if you want to smooth out the video best bet is messing with rates so middle stick is less sensitive (I forget if I used RC rate or super rate but basically tried to make the curves look flat and helps so small adjustments aren't as obvious/twitchy looking). Some of it is just going with whatever direction you picked too or planning out a path and trying it a few times to figure out where you are over-adjusting direction.
@wafflejock I actually adjusted the rates a little this time gonna give it another try this weekend hopefully thanx for watching buddy!
Nice, yah my tune and setup is still pretty far from perfect but been really trying to learn to find lines I can fly smoothly and just stop myself from making micro adjustments when not needed but it's a pretty difficult thing learn to do well (LeDrib is really incredible at the smooth flights pretty recent one called "laminer flow" blew my mind).
