Dronemadness
Realacc D215 FPV Racing Frame Kit
Realacc D215 FPV Racing X Frame
Brand: Realacc
Item: D215
Wheel base: 215mm
Weight: 110g
Material: carbon fiber
PDB: 5V & 12V
Thickness of frame arm: 4mm
Thickness of side plate: 1.5mm
Thickness of arm plywood: 2mm
Thickness of antenna plate: 1.5mm
High strength carbon board to ensure that the framework is strong.
4mm thickness frame arms' design.
True "X" frame, suitable for racing and freestyle flying.
With a PDB integrated BEC (5/12v output)
Racerstar BR2305S 2400KV Motor
Brand: Racerstar
Item name: BR2305S 2400KV Brushless Motor
RPM/V: 2400KV
Height: 32.5mm
Width: 28.5mm
Shaft diameter: M5
Motor mount hole size: M3
Weight: 30 grams
Voltage: 2-5S
Battery: 2-5S lipo battery
Internal resistance: Ω
Usage: X210 X220 250 280 300 FPV Racing Frame
Due to the Racerstar misprinting the label, the first batch of motors come with the label "BR2305" , but the performance is the same as "BR2305S".
We will correct the error in the next batch.
Racerstar RS40A V2 BLHELI_S BB2 ESC
Brand Name: Racerstar
Item Name: 40A BLHELI_S BB2 2-5S Brushless ESC
Model: RS40A
Con. Current: 40A
Peak Current: 45A (10S)
BEC: No
Lipo: 2-5S
Programmer: YES
Weight: 9.6g
Size(PCB): 32x15mm
-Mini size and light weight (9.6g)
-BLheli_S Firmware
-BB2 Chip
-D-Shot 600 in default
- Support Oneshot125, Multishot, Dshot150 and Dshot300.
Omnibus Betaflight 3.2 F4 V2.1
Item name: F4 V2.1 flight controller
Mounting hole: 30.5x30.5mm
Firmware: betaflight_3.2.0_OMNIBUSF4SD
Input voltage: 2-6S
SCM: STM32 F405 MCU
Sensor: SPI Sensor ICM-20608
Berometer: BMP280
Slot: standard SD card slot
BEC: 5V/3A
STM32 F405 MCU, Runs betaflight_3.2.0_OMNIBUSF4SD, could run faster loop time.
Using F4 MCU controls OSD over SPI bus in DMA mode.
OSD Configation has been included in Betaflight GUI.
Built-in 5V/3A BEC.
Built-in galvanometer.
With LC filter.
Racerstar 5042 3 Blade Propeller
Brand: Racerstar
Item name: 5042 3 Blade Propeller
Material: PC
Color: red, pink, green, blue, yellow, black
Quantity: 10 pairs (the same color)
Mounting hole: 5mm
Weight: 90.2g (10 pairs)
9.02 (1 pair)
YOU CAN GRAB IT AT BANGGOOD
Brand: Realacc
Item: D215
Wheel base: 215mm
Weight: 110g
PDB: 5V & 12V
Brand: Racerstar
RPM/V: 2400KV
Height: 32.5mm
Width: 28.5mm
Shaft diameter: M5
Weight: 30 grams
Voltage: 2-5S
Model: RS40A
Con. Current: 40A
BEC: No
Lipo: 2-5S
Programmer: YES
Weight: 9.6g
Size(PCB): 32x15mm
-BLheli_S Firmware
-BB2 Chip
Input voltage: 2-6S
SCM: STM32 F405 MCU
Berometer: BMP280
BEC: 5V/3A
Built-in 5V/3A BEC.
With LC filter.
Brand: Racerstar
Material: PC
Mounting hole: 5mm
9.02 (1 pair)
