brett.freese
I am building a quadcopter that will use the sunrise cicada 30A 4 in 1 ESC, and an F4 Flame FC. The ESC has 2 (what I believe) are 16 gauge wires for +V and GND, as well as five thinner wires, four of which are signal wires for the motors and connect to the FC, and the last one another GND wire. The FC has a signal pad for each motor as well as a +V and -V pad for each motor. Since I am using a 4 in 1 ESC (which only has one set of +V and GND wires + another random smaller GND wire) I do not know how I am supposed to connect the ESC to the FC. I know that I am supposed to solder the signal wires from the ESC to the signal pads on the FC, but don't I need other connections as well?
The 16 gauge wires coming from the ESC (the fat red and black ones) look as if I am supposed to solder them to a XT60 plug and then plug that into the battery, but I thought I was supposed to connect the battery to the FC and not to the ESC? Or are the 16 gauge wires meant to solder onto the FC (the big + and - pads), and then I plug the FC into the battery?
What is the fifth small wire (next to the signal wires) that is labeled GND for? Why doesn't it have a +V wire paired with it? Why only ground?
