Problem with Micro servos SG90
NHSA
Hi,
I am adding a FPV camera to my DIY Octocopter but have a problem with a micro servo SG9.
I have a NAZA v2 controller and a Futaba T8J transmitter with a Futaba R2008SB which is connected to the NAZA v2 via S-BUS.
I know channel 8 is free and can be activated via the transmitter.
The problem is that the Micro Servo does not work connected on channel 8 and transmitter with VR wheel. The strange thing is that a normal sized servo MG995 does accept the control on channel 8 and works as expected. I do not want to use that MG995 servo as it adds wight to my Octocopter.
Tested it also with a Tarot landing gear and that one works too as expected.
What could be the culprit that my Micro servos brand Tower Pro SG 90 does not work.
Testing the Micro Servo SG90 with a servo tester it does work as expected...
I am clueless.
Thanks Rainer
