PLEASE HELP 250 motors arm but won't spin up
Skytop
I am at a loss and have exhausted everything within my knowledge and research. I have a 250 quadcopter with Naze32 board, lumenier 12A simonk escs, fysky d4rII rx with taranis x9d plus tx. I am using betaflight to configure. I can get the motors to arm (green led lights and icon lights in betaflight) but the motors will not spin up. I've tried doing an esc calibration and I don't get beeping so I assume it's not working. I believe my min/max values are correct in Betaflight and with the Taranis, so I don't know what else to do to get these motors to spin up. Any suggestions would be greatly appreciated. Thank you.
Can you get the motors to spin in betaflight? Make sure your throttle channel isnt reversed.check signal wires from fc to escs. If it arms the rx and tx are communicating so im thinking either your transmitter/ fc isnt setup correctly in betaflight or theres no communication between yout fc and escs. Thats my 2 cents. Good luck.
Thank you Wildwelder. The motors will not spin in betaflight. All wires to/from the fc/escs are good, I don't see any issues there. I've attached some screenshots of betaflight - perhaps I missed something. The tx is new so I haven't flown it at all with this new tx.
