Skybird
| Just got this used P2 V3 V+ that may have been in some kind of crash I don't have much background on it, it has some small visible damage but the gimbal is intact and for the most part it looks like it may have been a minor crash, it came with the updated controller that charges, I've done IMU calibrations and stick on DJI assistant, the battery is at 75 percent it may need replacing. I can bind since I can move the gimble somewhat with the stickI haven't been able to get GPS lock, the major issue is even after the controller is on there is a steady blinking yellow light on the rear right light, I have searched all over for what that is, so far I found one comment on this video that is pretty much the same issue albeit it's the left rear light that blinks yellow so it seem it's pointing towards a ESC motor issue, maybe the motor was damaged or wiring in the crash. I hooked it up to the App and it says RTF no GPS I was outside and didn't get any GPS so maybe the GPS is shot too. Starting to be more workt than it's worth, what are you thoughts? So the yellow light goes away when you slick S1 6x and calibrate compass, so that's probably what it is but it comes and goes, no video both on DJI Vision and Litchi, so might be wifi module issue, gimble is responsive, no motors engaged mo matter what I've tried, so probably bad ESC controller, any thoughts on what I should I do? Thanks attached a snip my DJI Assistant upgrade screen it's all up to date maybe I need to downgrade? |
