Newbie
edessex
Hi all, i'm new to the drone world, i've just bought the Sky quad pro V2 and followed the set up to the letter (i think) the drone powers up but seems to fly off as soon as the power is high enough instead of hovering.... how do i calibrate the drone so all 4 rotors spin at the same time?
Check your instruction manual. It says to put the quad on a flat, level surface and bind it. Then push both sticks down and to the right and hold. You should get two "beeps" and a red light flash to confirm the gyro has re-calibrated.
A lot of quads use this same control sequence to calibrate.
