Nick
About to throw an arduino..*cough*F450 Master Race
Hello all,
My Girlfriend's Dad's Friend's Phantom took a swim in the Gulf and didn't bring its floaties. After the salty abyss choked the life out of it, it was then given to my Girlfriend's Brother (who has a Phantom 3 standard) for "parts". To re-iterate this is a Phantom 2 Vision Plus.
I wasn't so sure the phantom was a pile of junk and asked to be allowed to repair it.
Currently, I have replaced 2 ESCs and the patch on the GPS that's been know to be "Delicate". So now I have a grand total of 3 maybe working motors and the 4th having a burnt out ESC that will soon be replaced as well.
Also a note I do not have a genuine DJI battery and am simply using a cheap 3S 1800mah lipo and alligator clips to test the phantom... There will be no investment in a real $100 battery until I know the phantom actually works.
When I power it on it does a light sequence of something along the lines of "Red, Yellow, Green, Yellow, Red" and then no lights after that.
So lets list the good things so far:
1. 3 of the ESCs blink and chirp in union.
2. The transmitter does bind to the phantom and I can confirm the stick readings through the Phantom being plugged into my pc through the DJI assistant software.
3. The Wi-Fi Access Point does show up on a phone and can connect through the DJI app.
4. ..... Some fourth thing.
Now the list of bad things:
1. The fourth motor with the damaged ESC blinks a different sequence of lights on power up and doesn't seem to vibrate the motor while it chirps like the other motors.
2. No motors spin up or ESCS light blinks with the CSC execution.
3. DJI assistant software reads Compass Error "Abnormal Compass Data" with all the compass data reading as zeros.
4. No GPS information in the DJI assistant software.
5. Cannot get Transmitter to connect to RC Assistant software for firmware update and calibration (already update the phantom when it connected to the DJI assistant)
Probably the most annoying things are nothing happening on the CSC and the fact that the transmitter will not connect to my pc.
For the transmitter, I plug it in and it installs as a serial device (Not a DJI device even though I tried to install the DJI Drivers) showing as like "COMPORT4" or something. The Phantom also installs as a Serial Device "COMPORT6" but it shows up on the DJI assistant just fine. Yes I do have the separate RC Assistant Software but no matter what I do I cant get it to show up.
Any thought?
Any thought?
