Thomas de Rooij
Hi all!
This is my first post so I hope I'm providing enough information. I'm a student working with DroneTeam Twente to build a drone to join the UAS challenge but we've run into a problem. Our drone is a Funcub model, but we're testing it in quad mode. During our first test flight we attempted to take off but at high throttle, about 80%, some motors (differs per test which ones) start to stutter and then turn off. Watch
Our setup is as follows:
- PX4 FC
- DYS Aria 70A Blheli_32 ESCs
- HolyBro PM07 V2.3 power management board
- QX motor QA 2825 700KV motors
- 2 6S batteries in parallel
Our ESC signal and ground go straight into the PX4, since earlier we had issues with a ground loop when connecting the ground of the power supply of the ESC to the ground of the signal of the ESC. This lead to heavy stuttering, which seemed to be solved until now. The actual problem: In the attached video (click here to watch it) you can see one motor has a prop (it is turned around so it pushes into the ground for testing purposes) and the others don't, the ones that don't work fine.
Our ESC settings are as follows: .
We've tried changing the Rampup power, Demag compensation & motor timing, to . Our ESCs are rated for 70A and can handle 6S batteries, so this shouldn't be a problem.
Some more things to note: when activating the motors in QGroundControl this still happens.
Any clues how we could fix this or measure where it's going wrong? Any help is appreciated!
- PX4 FC
