P
psicmar-6
Guest
If you are having issues about your transmitter signal output blinking, i can give you a full explanation. what is for, how to use it and when, is a very useful function.
I will send it in two or three parts because apparently is to long.
I’m a new member and I don’t know how this forum works entirely. sorry. I’m a RC model airplane flier since several years and drones for a few.
About the issue of the transmitter signal indicator flashing I will explain. most transmitters have a function that allows you to lower the signal output. this is so you can perform a range signal test.
before you fly your new model is extremely important to do the following
first you must make Shure you have brand new battery’s in your transmitter, and the drone battery fully charged and do it where you have plenty of space, no high voltage wires and nothing in between you and your drone.
In the syma x8 series pressing the right trim in the right stick keeping it pressed and turning on the transmitter in the same time the signal indicator will start flashing. this means that the transmitter enter in low signal output.
next you turn on the drone link it and move the throttle so the motors start turning but just enough to not take off.
