Limited Supination
I want to build a 250 FPV Quad using the new Orange CF720X Micro 32bit Flight Controller
So I had a question on Hobby King site -
So with this Orange FC /RX , my t-six, 4 esc, 4 motor, and frame ... I can make a quad? Do I need anything else? Can a FPV camera plug into this for power? seems too easy? what am I missing?
And the response I got was this -
Randall
14 points
your missing the power distributor board that supplies this with 5 volts unless your escs have a BEC, if it does, then yes, it's that easy. it won't use openpilot but cleanflight naze32 instead, which is nicer in my opinion.
I knew I was missing something! So should I try to build this with power distrobution board? or put a BEC on each esc?
Would the power board also distribte power to fvp cam? run cam?
Then what about Nas32? Does it have ez stable flight as well as more acro flight when I get better?
I have never built a quad but I have some rc experience this dosen't seem too hard but I wish I had someone with knoledge of the new Orange FC / RX to help me...
So Far this is my buy list what do you think?
OK9154000026-0 - OrangeRX CF720X Micro 32bit Flight Contr..$39.2014
BK360000025-0 - A250 Carbon Fibre Racing Frame
This item is on backorder*$20.22180
OK206000012-0 - DYS BE1806-2300kv Brushless Multirotor M..$38.52160
OK9192000139-0 - Afro ESC 12Amp BEC UltraLite Multirotor ..$49.95150
OK329000305-0 - Gemfan Propeller 5x3 Green (CW/CCW) (2pc..$9.66140
OKN1300.3S.45 - Turnigy nano-tech 1300mAh 3S 45~90C Lipo..$28.98322
OK9568000022-0 - Quanum Q58-2 40 Channel 200mw FPV Transm..$19.4060
OK692000002-0 - RunCam PZ0420H-L28-N FPV Camera NTSC$22.40178
TOTAL: $228.331204g
Thanks in Advance for any help
Randall
![thumb_up.png](http://www.hobbyking.com/hobbyking/store/images/thumb_up.png)
![](http://www.hobbyking.com/hobbyking/store/images/18815282_delete.gif)
