hs120d prop
Anemsguy
Hello all. Just joined the forum today. Read lots of great info so far. I was looking for some help/suggestions on prop size and upgrades for my hs120d. Any benefit in getting a different prop than the ones that come with the drone? Looking for suggestions on size and materials as well as 3 blade designs. Thanks in advance.
In general more mass means more load on the motor and esc to change speed of the motor so a heavier prop could burn out components but more blades on a prop means more push per rotation. Essentially they probably chose a prop to get a given flight time but you could change potentially depending on the motor shaft.
