IlKaffeelI
Can someone provide some inside on how to fix the problems shown in the pictures?
1. I don't know how I would solder the battery wires back to the connector without damaging the insulation.
2. I could solder the two ends of the wire together, but the solder would be located at the hole in the plastic casing and I wouldn't be able to close it up again. I don't have much slack to play with in the wire and I'm not skilled enough to resolder all the wires to a new connector. Do I bring it to a pro?
Thanks in advance.
Thanks in advance.
