How do I connect park servos to FC?
Terestron
I am using a pair of park servos for retractable landing skids and I am not sure to how to go about it...
I am using a FS-i6S tx and FS-IA6B rx with a JIYI P2 FC... I was going to connect via PPM which gives me 8 channels...But I am reading I should power servos with separate BEC and just connect signal wire..but to where?
Hope this makes sense...
Most servos require 7.4 volts, so you could use a pololu or similar voltage drop-down regulator for power (assuming you are using 11.1 or 14.8 volt lipo) . Then signal wire would just go to channel 7 or 8 of your RX with channel set up in your TX for whatever 2-way switch you want to use.
How do you like that flight controller, seems pretty good for the price? Any problems with GPS lock or flyaways?
