Help with Syma x5c
Hi mate are props loose on motors, are motors spinning free , coreless motors damage easy in a crash, it can push the shaft down in the motor so it spins but has drag on the shaft so never gets its speed up to fly right
Hi mate no not really , if it was a brushless out runner you can use a tachometer on it , but coreless are cheap about £15 for 4 or less
Hi mate I think they are all the same ,not seeing the motors up close, I would not like to say get get these as I may be wrong , so get the OEM ,or if you can give me the size of the motor I will check the hubsan to see if they are the same
