Good news for x6b (flysky reciever)
Dugdog47
Damaged the antenna plug on reciever, buzzkill???:
Apparently there are solder pads on the back to direct solder antenna:
Question: can you just strip off some wire and direct solder an antenna? I'm going to do it anyway and just wondering what results I might expect?
Good idea or don't waste of kwad? What do yall think?
I do this with my video Tx antennas a lot cause I hate connectors. I just de-solder the ufl and use the same pads. You should use ground for the metal shielding, and the very center wire goes to ant. Should be fine with a receiver.
Yup just don't kink or shorten the exposed part of the antenna wire it should be around 12.3mm or whatever the speed of light is (roughly 3x10⁸ or 300,000,000 m/s divided by 2.4GHz (or 2.4 billion) and get 12.5mm as the length for a wave at that frequency.
It's working fine lol direct soldering reciever antennas is on the table.
Flysky gets a bum rap but the fact that make their $9 reciever easily repaired is cool!
