Negrete
The FrSky Pilot series flight controller is an All-in-One module that supports comprehensive flight control functions with pre-installed powerful INAV (The support of other open-source software like Ardupilot and Betaflight are ongoing.) and F.Port 2.0 software. This control system is targeted towards RC hobby enthusiasts who are looking for a complete system combining power management, a powerful graphic FrSky OSD, and plenty of IOs.
The R9/RXSR Pilot is comprised of a three-layer stack:
1.A mainboard providing power for servos and for a video system with switchable voltages, current measurement and general connectivity (6 full UARTs, I²C, 12 servo/motor outputs, 2 analog inputs, video input/output)
2.A processing board using a powerful STM32F765 at its core, boasting 1MB of flash memory, and 512KB of RAM capable of running the INAV, Ardupilot and Betaflight flight control software. It integrates an ICM20602 IMU, FrSky’s latest
graphic FrSky OSD
, and an SPL06 high precision barometer. An SPI bus connector allows for optional connection of a second vibration isolated IMU, which can be mounted to the board, or other peripherals. An SD card slot allows for data storage including BlackBox logging. It also includes a piezo audio transducer for system notifications and lost model locating.
Any FrSky receivers with a standard FPC interface can be connected directly to the processing board (RXSR-FC / R9MM-FC-OTA). All F.Port 2.0 Capable Receivers (Archer and Tandem Series Receivers, etc.), SBUS receivers, and some others with serial ports are also compatible.
FEATURES
Supports FrSky
F.Port 2.0
Protocol
12 Servo/Motor Outputs & Multiple Serial Ports (6 UARTs, I²C, SPI)
Powerful STM32F765 Based Flight Controller is capable Running on INAV / Ardupilot / Betaflight Firmware
Built-in
Graphic FrSky OSD
Supports FrSky S.Port Sensors
Built-in Multiple Sensors
Max 150A Capable Hall-effect Current Sensor
Built-in 3-axis Gyroscope & 3-axis Accelerometer Sensor (ICM20602IMU, ±2000dps, ±16g)
Supports ICM20601/ICM20602/MPU6000 IMU as external gyroscope module with vibration insulated box
Built-in Barometer sensor(SPL06-001)
Adjustable Voltage Output through integrated BEC function
Supports Black Box Data Record Function(via SD card)
Compatible Receiver
Standard FPC Interface on-board receiver with a perfect fit protection box (RXSR-FC/R9MM-FC-OTA, etc.)
SBUS Receivers and Some Others with Serial Ports
SPECIFICATIONS:
Dimension: 60*45*14mm (L*W*H)
Weight: 35g (Without connector)
Mounting(FC): 30.5*30.5mm with M3 grommets
Mounting(Rx): 13*13mm (R9MM-FC-OTA / RXSR-FC)
Battery Port: XT60 Plug
MCU: STM32F765VG (1MB Flash Memory, 512KB RAM)
IMU: ICM20602 (±2000dps, ±16g)
Barometer: SPL06-001
Graphic OSD:
FrSky OSD
Micro SD Slot
12* PWM Outputs
6* Full UARTs (Any UART can be configured to the S.Port via INAV)
1* I2C
2* Analog Inputs (0-3.3V)
1* Video Input
1* Video Output
1* Piezo Audio Transducer
2* ESC Power Pads
Voltage Range: DC 11.1V~51V (3S~12S Li-Po/Li-ion)
Current Sensor: Max 150A
BECs:
graphic FrSky OSD
FEATURES
Supports FrSky
F.Port 2.0
Protocol
Built-in
Graphic FrSky OSD
Compatible Receiver
SPECIFICATIONS:
Graphic OSD:
FrSky OSD
Micro SD Slot
12* PWM Outputs
1* I2C
1* Video Input
1* Video Output
2* ESC Power Pads
BECs:
