None that I can recommend and in fact, I wouldn't recommend using a GoPro for FPV at all.
Here's an exerpt from the guys at TBS:
1) GoPro requires a separate battery to deliver a picture. If that battery goes flat, we lose picture. If we forget to charge it, we can't go fly. Single-battery systems are an essential part of our security philosophy.
2) The GoPro A/V out connector is out the side, which creates a significant point of failure on hard landings or flying through trees and bushes. Cables sticking out the sides can catch on to branches and pull out or break the whole camera.
3) The GoPro does not work well in dusk or dawn. The ground is sometimes too dark when flying against the sun. A "WDR" security camera delivers better picture to the pilot
4) Our video transmitter use 4:3 aspect ratio, the AV output on the GoPro uses whatever we record at, which is 16:9. This reduces the resolution of the transmitted picture.
5) The GoPro has latency on the video output. While this latency is negligible when flying high altitude or slow, down on the ground when fast reactions are required the latency will be a problem.
6) The GoPro can inject RF noise back into your R/C system and deteriorate its range when it's being powered from the same battery as the receiver.
