FLYPRO PX400 Flight
Hobby Wow
Vendor
Merchant
Quadcopter
Weight (with battery): 2450g
Max takeoff weight: 2900g
Hovering accuracy: Vertical: 0.5m - level: 2.5m
Max rotational angular velocity: Pitch axis 180°/s - Heading axis: 90°/s Max pitch angle 45°
Max ascending speed: 5m / s
Max descending speed: 4m / s Max flight speed 20m / s
Max altitude: 1000 m
Withstand wind speed: 10m / s
Max flight time: ~ 25 mins
Motor Model: FLYPRO2814
Propeller Model: FLYPRO1147 carbon propeller
Operating temperature range: -10° to 40°C
Wheelbase: 480 mm
Dimensions: 610 * 610 * 280 mm
Remote Control
Radio Frequency: 2.4GHz DSSS FM
Max radio reception range (without interference): 1km
Battery
Capacity: 5400mAh
Voltage: 22.2V
Type: LiPo 6S
Energy: 120Wh
Battery weight: 630g
Charging temperature range:0° to 40°C
Ground Station APP
System requirements for mobile version:
Android 4.0 or later with Google Services Framework
Optical flow camera sonar positioning
Max flight speed: 8m/s
Sonar height measurement range: 0.3m to 2.8m
Operating environment: The ground is rich textures, light enough (normal indoor fluorescent lighting)
Hovering Accuracy: 0 to 5.5m
