First quad build need help!!
Jason bingamon
Hey guys so this is my first build first every thing I went with the naze 32 turnigy esc 2300 kv motors from hobby king I got a power distribution board and a fly sky fs t6 6 channel transmitter that came with a reciever I got everything wired up and was using the clean flight app on Google to configure everything I had motors spooling up and spinning the correct way but when I try and use the transmitter to do anything I get no response from the quad the system has been binded and I get the solid red light like it's supposed to but nothing I can't find any video or post with any one having this problem plz help!!
HI mate and welcome , are you arming the FCB , after you power the quad up , there will be a way to arm the quad , then your have throttle control
Check throttle settings they should be 1000 low end and full throttle will be 2000 approx
To arm by stick leave cyclic in the middle, then pull throttle down and right this is to arm
disarm throttle down and left
manual
https://www.google.co.uk/url?sa=t&r...4sJqvioP-nTFz2CoQ&sig2=rn-2Pkw3ymwLebbK4ARTYw
