First build esc help
eXangelR
Hi there guys,
Can somebody help me please with an advice about ESC for my future build?
I have decided to take these motors for DT silver blade 240 drone build:
https://flyingfolk.com/produkt/stor...ultirotor-brushless-motor-copter-multicopter/
I understand that I need 4pcs of ESC with minimum value of 16A for example:
https://flyingfolk.com/produkt/spedix-es30-hv-30a-3-6s-blhelis-fpv-racing-brushless-esc/
But if I want to use 4 in 1 ESC board, is this one for example suitable?
https://flyingfolk.com/produkt/jhem...s-esc-30-5-30-5mm-fpv-rc-racing-quadrocopter/
That value 4 in 1 ESC board 55A means that this board can power up 4 motors each with 55A or together? So for my build with motors with max current 16A each it would be not enough? (4 x 16 = 64A)
Thank you for exlanation in advance.
Another thing to think of is if a esc gets damaged in a crash you only have to replace one not a 4 in 1
Look at lazy zero web site he does loads of flash ware for FCB and ESCs. May help you as you can get cheaper esc and reflash them with better firmware
