Yeah, I like 'em a lot. I got one that I've rebuilt on a 120mm frame and stuck 65mm props on it. Oh, little difference, I started with the QX90C.......I'm able to pull off all of my freestyle maneuvers with this little baby. Plenty of power and stable. Every now and then it will stall in hard turns, but quickly recovers.
Yep, they’re the same motors, but the new one comes with a high voltage battery and that little sucker scoots I’m telling ya.I've got the qx90, yes they are very good tiny quads. I think the 90 and 95 have the same motors.
Take a look on your FC. You may find a "bus" that solder jumped marks 1s. If it's there you should also have an open side marked 2s. Remove the solder jumper from the 1s bus and jump the 2s bus and you can use the 2s batts..........not all of the FCs have this but many do...........Yep, they’re the same motors, but the new one comes with a high voltage battery and that little sucker scoots I’m telling ya.
