Does my prop setup in properly?
koklimabc
Active Member
As per topic, I suspect my prop setup could have wrong directional setup
I'm using prop out (reversed directional). It just spin out vertically 360 degree and drop into ground.
Then my telemetry lost to my controller. why?
Hi it's hard to see in the photos but a standard set up is
Front left CW
Front right CCW
Rear left CCW
Rear right CW
So what was the fix , it help others if you can say what was wrong
That is easy, I'd just change "Yaw degree" to 90 (can be 180, 270) degree for FC alignment (Configuration tab of betaflight), since my VBAT + & -
(Battery Terminal) shifted to left side, I'd also manage to change resource motor to correct direction (CLI command : set resource motor 1 XX),
"prop out style (reverse)" requires my prop to have lead out (most thickness edge must face out side).
