Kiko.Z
DHD D1 Drone biggest selling point of course is a super mini fuselage, the size is only 22 x 22 x 20 mm, compared to Cheerson CX-10C (40 x 40 x 22 mm) , its volume only one-third of the latter. DHD D1 Drone main is for indoor flight, fuselage design with other mini quad is very close, aso a wholly integrated models of Ready to Fly, after the quad power on, open the transmitter power on to completes to the code, then it can take off.
DHD D1 Drone (left) compare with the world's smallest aerial quadcopter Cheerson CX-10C (right)
Fuselage only 22 x 22 x 20mm, super mini size
DHD D1 Drone's bottom details, the embedded 3.7V / 80mAh rechargeable batteries.
DHD D1 Drone was really very tiny, so the charging interface to prominent in outside of fuselage.
DHD D1 Drone sides of the body has LED lights, easy to identify the direction.
Remote control: Can be stored DHD D1 Drone
DHD D1 Drone transmitter significantly large than other mini quad due to the airframe storage space. You can put the whole drone inside the remote control, then close the transparent protective cover, easy to carry. Unfortunately, the remote control no further integrate charging function, it can not be directly charged for the drone quadcopter. Has two joystick on the remote control, for controlling the throttle, drone head direction, and front, rear, left and right side fly; at the same time, he cross button used for front and rear, left and right trim. To switch flight speed, headless flight mode or a key 3D tumbling, pressing down the joystick to perform.
DHD D1 Drone remote control capable of containing the whole mini drone.
DHD D1 mini drone with separate Switches.
Flight operations: stability sufficiently high
Although is a super mini drone, but DHD D1 Drone has built 6-axis gyroscope, the flight is very stable. Compared with Cherrson CX-10C, it's height control and steering are easier. Indoors or outdoors breeze environment, duuring test flight, found it have good wind resistance, the operation is simple and easy.
Switchable flight speed, equipped with 3 speeds to choose. In the most high-speed mode, DHD D1 Drone synchronized start "headless" flight mode. As hard pressed to the right of the joystick, and then moved it in any direction, you can perform fancy 3D tumbling action. D1 Drone uses 3.7V / 80mAh rechargeable battery, actual flight time is about 5 minutes(tested it); charging via USB, takes about 20 minutes.
DHD D1 Mini Drone Conclusion
In the name of the world's smallest quad drone, successfully attracted the attention of many players, plus flight stability is very high, control is simple&easy, it's a great potential gift for Christmas & New Years.
