Good day, everyone!
I'm working on a design that starts with a standard Colpitts oscillator. As an example, consider the following:
It works, but I'm not sure how to determine the values of the individual components. I've run several simulations and have a paper with numbers and results, but I'm still stumped about which two Cs to use for the LC tank. If the values are not properly matched to those of the coil, the oscillation does not start or is distorted (even if the relationship between Cs is roughly 10). I've been looking for a direct solution to this question, but despite a few discussions on the issue, there aren't any conclusive responses in the forum.
I know F=1/(2pi sqrt(LC)), but I can't see making a 5 Mhz oscillator with an mH coil and pF coils, or a 5Khz with a 1uH coil and 1000uF capacitors (approximate values).
I'm not sure, but I believe it all has to do with the components' impedances. In any manner possible, the impedance should be matched to the amplifiers in and out resistances. It could be an issue with common-base amplifiers.
