GlassKnees
This question has come to me several times over the last year or so. Can one fly two quads using the same transmitter? I think you can. All you have to do is bind both receivers to the same transmitter.
But why would you want to do this? Since both aircraft are getting the same signals and responding the same way, except perhaps for minor differences in performance, wouldn't it be dangerous? Well, yes, unless perhaps both quads had mission way point capabilities. You could plan separate waypoint missions - I'm thinking of having my Tarot Iron Man, with a gimbal and camera set up, fly a couple of meters above and behind my Parallax Elev-8 - I could shoot video of my Elev-8 in flight....
I can set the two aircraft apart and set up each mission so that they fly to their respective first waypoint and loiter for a couple of seconds - I can have the Tarot linger a tad longer to give the Elev-8 a chance to depart on its course. I can set the altitude a meter or two higher than the Elev-8's and simply have the Tarot follow at the same speed. At the end, they would each land at their respective takeoff points.
What if something goes wrong? Well, I can select any one of three flight modes which I can select via a three position switch on my transmitter. Typically, I set Stabilize, Auto (fly the waypoint mission autonomously), and RTL. On the Elev-8 I can set the third flight mode to Land and the Tarot to RTL - that way if something goes awry I can immediately land the Elev-8 and have the Tarot head back for home (I can take over manually again after the Elev-8 has landed and disarmed).
Another thing I can do is take advantage of APM's ch 9 which I used to autotune the Elev-8 - I can change the ch 9 selection on the extended tuning page in Mission Planner from autotune to Land - that way, I can flip the GEAR switch on the transmitter to cause the Elev-8 to land without affecting the Tarot's flight. But I would have to experiement - will toggling the GEAR switch override the autopilot, or do I have to be in a manual (Stabilize, Alt Hold) mode in order for it to work?
If I Can work out the math and test the safety contingencies, I think it would be fun to capture video of my Elev-8 in flight from above...
