Quadcopter102
Having used CC3D and KK2.1.5 - I thought it wise to try the Naze32 - which seems more widely used.
I can and have updated it and used Baseflight...BUT for the life of me.. I cannot get it to load into Cleanflight. It does not auto connect and a manual connect fails after 10 seconds.
Using the above two FCs - I found the esc/motor connections easy to follow. Now I accept I am new to this and must be partially brain dead - but I cannot really follow the pin wiring system.
I see motors 1-2-3-4..... but no indication of which colour wire to use in the supplied breakout cable.
Possibly using the CC3D and its colour coding is blocking me dealing with this - that and seeing
DO NOT GET WIRE POLARITY REVERSED - THIS WILL INSTANTLY DESTROY THE HARDWARE - does not help.
The breakout cable I have is a series of black, white, orange, red, brown. I have seen vids of older version with different colour wires.
Also, I am not sure about the ESCs - the ones I plan to use have the red,white, black wires....are these OK or do I have to use just the white signal wire.
Any other advice welcome....
