davidhk129
I don't know about you fellas. I always find it hard to work with those tiny, slippery hex keys. Many times it slipped out of my hand before I could finish what I intended to do with it. Maybe I have clumsy fingers.
I did search for user-friendly handles for them from many hardware stores. Either too expensive or wrong type/size.
By coincident, I've found what I needed from you-tube. Would like to share this with those who experience similar frustration.
www.thingiverse.com
Adding : You may find difficulty screwing the nut into the handle. Try a few times and add a few drops of lubricant will do the trick. Bear in mind that these are 3D printed parts from a hobby type 3D printer. Don't expect perfect fit.
T-bar handle and nut (3D printed)
Universal T Handle by MakeLikeMike
I made an universal T bar handle as a one fits all solution. Since I didn't want to print a handle for every hex key, I made one that fits all the six sizes. You can easily switch between the keys. The smallest hex key isn't perfectly centred but can still be used properly.I was inspired by...
