slowllllly making progress on my tarot 650s build and I just hooked up the retracts for the first time. I hooked the servi cable from the retract controller to the gear location of the receiver. Initially nothing was happening so I flipped the sevo cable end on the receiver from top to bottom and got a response. I tempoarily soldered the power cable from the retract controller directly to the distribution board. Parallel to one of the esc.
MyProblem is either only 1 leg will function at a time or, more often, neither won't function at all. You just hearing a clicking sound and then nothing. The light on the retract controller flashes when I hit the switch. Am I doing something wrong or are the retracts defective.
