garthkh
Please explain to me (or point me to a practical link) the transmit/receive sequence between a controller in ones hand and a drone. Hopefully with good explanatory pictures.
My budget drone is a $300 5G FPV with a 2.4GHz controller frequency for the basic hand controller. There is no display on the controller - only some lights. The Phone App, I presume, controls the drone via the 5G link (or not?). My drone is a Kai One Max and has 3 antennas - I stripped it right down to see what's inside and done a few mods.
I am an ex Radio Ham and I'm trying to figure out the TX/RX links in the controls. When I connect the hand controller to the drone there is a delay before flight until the drone tells the controller that it has found 8 satellites. A light comes on on the controller. So some telemetry has been received by the controller via the 2.4GHz link. Also, if I flyout of range, the controller is notified that the drone is now in RTH mode. Therefore there is a receiver in the controller. Does this receiver share the same single antenna?
The Phone App can also control the drone without the use of the basic hand controller and the phone App controls the drone, receives video and images from the onboard camera , AND it receives telemetry regarding the satellites, distance, height, etc . The drone's wifi board for the 5.8GHz signals use two antennas. Is one TX and the other RX?
So my question is actually twofold -
1. How the TX/RX signals share a single antenna on the hand controller.
2. Is it possible to enhance my hand controller with some form of telemetry board and display to show the same as I'm getting on the phone App display? IE. the battery status, compass, satellites, height, distance. I have already modified the controller and the drone to improve the antennas, and have doubled the flight and video range. I'd like to try and add this extension if possible.
These images are of the telemetry display on the top of the phone App display and the antenna tests I've been trying out. The cloverleaf is definitely the best and two 5.8GHz cloverleaf addon's on the drone for improved video.
