I'm not sure I understand what you mean ?
By putting the aluminium prop adapters on the 350 qx it has made the props sit slightly higher which prevents any props from hitting the frame.
The copper tape fitted inside the 350 qx has created a shield between the Gopro and the GPS antenna which was only a problem when I started to record. I would have a solid green light indicating GPS lock but as soon as I pressed the record button on my GoPro 2 then the green light would start flashing indicating that it had lost GPS and was now looking again. Turning off record would get my GPS signal back almost instantly. I was going to cover my GoPro waterproof case with copper tape but found someone on YouTube who had used aluminium tape inside their 350 qx so I decided to go with this fix because it looked neater, plus I like to use my GoPro for other things too so didn't really want it all taped up.
Here is a YouTube link tutorial on how to fix the GoPro GPS issue and another short YouTube clip of my copper tape fix.
