Hello!
I recently had a bad crash, I flew right into a metal poll! That's what flying with low light got me....anyway, I'm flying an armattan chameleon and it took it very well, only some bent aluminum and one solder joint on one esc popped off...so after making my repairs the quad is literally flipping out on throttle increases. Basically I can take off and hover no problem, but as soon as I blip the throttle it flips out. I then calibrated the esc's and saw no difference. I then ran betaflight and ran each motor in the "motors" section. 3 out of the 4 motors experience stuttering when applying a quick full throttle, but one has no problems. If I ease each motor up slowly to fully throttle there is no problem....it's only when I increase throttle quickly that 3 of the 4 stutter. I've looked over everything and I cannot see visual damage to components...speaking of which is all armattan stuff, armattan 30 amp esc's and armattan motors. Any ideas of what this is or how I might find out? Damaged flight controller? This is a spracingf4 board with built in pdb, did the pdb get damaged? Thank you so much!
-Kevin
-Kevin
