Motor replacement for Sky Viper 2450 HD
kjoiner
I have a Sky Viper V2450 HD and the front right motor has failed. I ordered a new set of motors from Sky Rocket but the wire colors are different. The original wires are red/black and white/black. The new motor wires are red/blue and red/white. I'm not sure what goes where.
One clue may be the plastic caps on the rear of the motors. On the original, the red/black wired motors have a gray cap.
On the new motors, the red/white wired ones have a gray cap.
I could reassemble the drone with the new motors and test it, but I would rather see if anyone already knows.
Thanks!
Kyle
You will have one wire that will be the same color on both, this is the ground.
So on your new motors, red is the same as black on your old motors. On your new motors, white is the same as red on the old moter and blue new is the same as red old
No problem. Just be sure to put the new motor with the grey cap on the same side as the old one or your motors will be reversed
