Hi, I'm currently using a separate low voltage alarm from Hobbyking that detects if any cell drops below 3.3V. However, I'm not sure if 3.3V/cell (9.9V for 3s) is too low, as the manual for the KK2.1.5 suggests a low voltage setting of 10.8V. That's why I'm trying to hook the battery up to the kk 2.1.5 for better overall control.
From what I could gather, I just need a male to female jumper cable to the positive port on the kk board, but after that I'm not sure if it should be to the red wire on the balance charger cable or to the red main wire of the battery. I'm almost positive that they both do the same thing and are in parallel but I'm apprehensive of experimenting as I'm not sure if it would fry the board. Some clarification would be appreciated! Thanks!
Also, any tips on reducing vibrations? I tried balancing the props but I'm not very good at it yet. Sometimes they seem balanced but when I measure again, they still keep moving around.
