Dear All,
I am aiming at building a sturdy, stable, FPV quadcopter that weight less than 800g including everything. I am not really interested in acrobatics, but rather in video quality and stability as well as in ease of flight. I can handle electronics, programming, PID setup, but I am not a gifted pilot. So I expect the FC to behave well. I have selected all the parts, but I am unsure...
ABOUT THE FRAME
PART LIST
WEIGHT
QUESTIONS
I have attached to this post ecalc computation results as well as a better formatted part list with additional info that also shows the pilot gear.
Thanks for your patience and help.
Alyssa
ABOUT THE FRAME
My frame will be an aluminum and plywood that should weight 229 g for 9" propellers with 2" clearance between them (propeller tip to tip distance).
QUESTION: Is 2" enough clearance between propellers?
PART LIST
MOTORS: QUANUM MT 2212 1000 kv motors, 52 g
PROPS: Multirotor Carbon Fiber T-Style Propeller 9x5.5
ESC: ZTW Spider Series 18A OPTO Multi-Rotor ESC 2~4S BLHeli/SimonK
BATTERY: ZIPPY Compact 2700mAh 3S 25C Lipo Pack
GPS: Tiny GPS for NANO N32plus Flight Controller
FPV CAMERA: RunCam Swift 2 600TVL FPV Camera NTSC Top Plug
FPV TX: Quanum ELITE QE58-2 5.8GHz Selectable 25mW - 200mW Wireless AV Transmitter
UBEC: Spider Pro Series 5V/2A UBEC
LIPO ALARM: HobbyKing™ Lipoly Low Voltage Alarm (2s~4s)
BATTERY STRAP: Hook and Loop Universal Tie Down 300mm
RECEIVER: Turnigy 9X 2.4GHz 8Ch Receiver (V2)
Note: I found no 2500 mAh that weigh less than this 2700 mAh in the EU warehouse of HK
FLIGHT CONTROLER:NANO N32-Plus Flight Control Board (Naze32 Compat)GPS: Tiny GPS for NANO N32plus Flight Controller
WEIGHT
All this should weight around 750 g leaving me 42 g (to 799 g) for unforseen weight (Though I took cables, connectors, etc.. into account).
QUESTIONS
Based on your experience, is there any part that I should replace? Will every every part play well with the others? Will it fly? Perform as expected?
Alyssa
