Jackson
USA member at large
Well I got my $47 Syma X8C on special from BG and decided to check it out. Everything seems fine, FWIW all the props were heavy on the A/B raised letter side. I just ran it inside (not flying) for a while to run in the motors. Decided to check the 2mp camera.
It was overcast and the sun was going down and was about 7 degrees with 17 mph winds, way too cold for me. But I stepped outside for a quick test. Here it is.
http://sendvid.com/exzoae1t
Just for grins I ran it through Virtualdub (a rather old open source app) using the Deshaker filter with 2 passes. This is the result. You can see how it's constantly try to adjust.
http://sendvid.com/e6i8yivb
Then once again using the 'border' option, which zooms the image. Obviously the original vid was beyond hope, but this is a good example on these filters work.
http://sendvid.com/p09cochq
