agridronedesigner
The stirring plate of spreader can make blocky or sticky particles more uniform, and spreading operation smoother. Take EFT's spreader as an example to introduce how to quickly upgrade EPS200's stir bar to stir plate.
Step: Disassemble the spreader from the tank, remove the top screw, take out the stir bar, install the new stirring plate, then tighten the screw, the stirring bar is upgraded successfully.
As you can see, the umbrella-shaped metal stirring plate increased the force area and stir with greater power, which makes sowing smooth and non-blocking.
