Hi, recently I made my first built, it flew fine the first times but after a crash i started to notice really bad high frequency oscillation and video noise at high throttle and when airmode is enable with the quad on the ground the motors continuously change speed.
Here a blackbox video, when i go full throttle at 0:10 and 0:37 the motors start twitching and changing speed super fast, in some moments some of them are bellow 50 % power while they should be near 100%
I notice a slightly damaged component on the ESC i don't know if that's the problem:
here a video where I enable airmode with the quad on the ground, if you listen carefully you will notice the motors slightly twitching and changing speed:
Could be the ESC? Some bad motors? Or maybe the FC is damaged ?
Any help or advice would be appreciated.
