This is my first quadcopter build and before purchasing all the things I need I wanted to check if everything will work fine.
These are the things I am planning to buy:
Frame: Hobbyking X666 Glass Fibre Frame
http://www.hobbyking.com/hobbyking/...ber_Quadcopter_Frame_666mm_UK_Warehouse_.html
Motors: Quanum MT Series 2227 800KV
http://www.hobbyking.com/hobbyking/..._Brushless_Multirotor_Motor_Built_by_DYS.html
ESC: Hobbyking 20A Blue Series Brushless
http://www.hobbyking.com/hobbyking/...Brushless_Speed_Controller_UK_Warehouse_.html
Props: 1047 SF Carbon Fibre Props
http://www.hobbyking.com/hobbyking/..._Propellers_L_H_and_R_H_Rotation_1_pair_.html
Battery: Multistart High Capacity 4s 10,000 mAh LiPo
http://www.hobbyking.com/hobbyking/...0mAh_Multi_Rotor_Lipo_Pack_UK_Warehouse_.html
Power Distribution: Hobbyking Quadcopter Power Distribution Board
http://www.hobbyking.com/hobbyking/...r_Power_Distribution_Board_UK_Warehouse_.html
Transmitter: Turnigy 9x
http://www.hobbyking.com/hobbyking/...mware_UK_Warehouse_.html?strSearch=turnigy 9x
I will also be using Multiwii Pro flight controller with a GPS module.
If you could let me know if all of this would work well with each other and any suggestions if not!
Thanks a lot in advance
