Jurriaan
I have this transmitter module and receiver in my Turnigy 9XR Pro radio:
http://www.hobbyking.com/hobbyking/store/__14355__FrSky_DF_2_4Ghz_Combo_Pack_for_JR_w_Module_RX.html
I read the following warning in the FrSky manual: “Warning: HS mode is only applied for high-speed digital servos. Other servos should select FS mode, otherwise servos will get hot and may burn out.”
I have these motors:
- D2830-11 1000kv
- AX-2810Q-750KV
Just a minor warning, but it has brought me a lot of questions and haven’t found answers yet. Does anyone have an idea about the following questions:
*Open pilot screenshot: http://www.luftknipser.de/wpcontent/uploads/2015/08/openpilot_esc_auswahl.jpg
- D2830-11 1000kv
- AX-2810Q-750KV
- What is the main difference between analog and digital motors?
- How do you recognize whether you have a digital or analog motor?
- Is this something you also have to configure within your FC? Because I see in the open pilot (CC3D) software the option to select standard speed or rapid*. Has this something to do with HS and FS mode?
- Or is this question irrelevant because the receiver is connected to the FC, the FC to the ESC and ESC to the motor?
