Batman 220
Hi
Need some advice before I purchase the crossfire micro bundle. I run the manba f4 stack in all my race builds and use the taranis QX7. Also run XM receivers currently.
1. Will the crossfire mod be compatible with the manba f4 fc due to uart inversion / un inversion. And is it possible to change in the cli to make it work?
2. Does crossfire need two uarts (receive and transmit) I assume a third uart is not required for smart audio? I'm limited on uarts on the manba stack.
3. Should I be looking at the access protocol instead to reduce latency?
Thanks in advance you guys have been awesome in the past.
