sLwrangler2000
5GHz Live Video Transmission
Seize the moment with 2K HD 110° FOV 90° adjustable Camera . 5GHz Transmission ensures crystal live video transmission up to 2600 FT.
30-min Modular Battery
Enjoy a maximum of 22-min flight time with FPV transmission off. The battery is easy to put or replace.
Brushless Motor
1500KV long-lasting brushless motor gives you a Quiet and Powerful flight. Won’t die due to crash or high temperature like brush motors.
Quick-Release Propellers
The upgraded propellers run more efficiently and powerfully. No Screws Required to Set Propellers up.
Simple Control
Quick launch by pressing one key start. It can fly while keeping its altitude locked. This allows the pilot to focus on camera control and enable more complex shots.
GPS Follow Me
Shot with ease when the drone can follow you with camera pointing to you. Free your hands to take photos or videos. Edit and Share your new creations to social media!
Auto Return
HS700D can always fly back to Take-off Point as per your instruction or whenever it runs out of power or loses connection, even when you accidentally fly it out of range.
Custom Flight Path
App control available. Simply draw a route on the App screen and the HS700D will move in that direction or in a circle and send back real time landscape to you.
Specification
- Item weight: 608g ( FAA Needed)
- Dimension: 8.66*8.66* 6.10in (Without protection guards)
- Flight Time: 22Mins
- Charging Time: 5-7Hours
- Camera: 2048*1152p / 2k
- Live Video Transmission Range: 1640-2600ft
- Max Control Range: 3280ft
- Battery Capacity: 2800 mAh
- Motor: 2204 1500KV Brushless Motor
Attention:
- Drone App work with IOS 8.0 or Above & Android 5.0.2 or Above
- Protection guards protect person, property and the drone itself.
- Please fly in open and GPS covered area.
Package:
- 1*Drone (with Manual)
- 1*Transmitter (with Phone Holder)
- 1*Drone Battery/USB Charging Cable/ Dual Balance Charger
- 8*Propellers (with Propellers Spanner)
- 2*Landing Gear
- 1*Screwdriver
- Transmitter is underneath the package. Be careful when take the package out from box.
- The smartphone screen it not included
Learn More - https://amzn.to/37MbaPW
Like Our page for more Drone info.
