Blomgren92
Bought a visuo xs809hw and wanted after awhile to upgrade the battery. Are some instruction videos on how to do this and followed them. Bought a 18650 panasonic battery and a tp4056. Soldered them togheter but when i test it only works for about 1 min. When checking voltage its full (4.2v) just restart the copter and it works again for 1 min. Whats the problem?
Search youtube for visuo xs809hw battery mod
Battery specs;
Rated Capacity: 3170mAh (0.634A discharge at 20°C)
Capacity (Minimum): 3220mAh (0.644A discharge at 25°C)
Capacity (Typical): 3350mAh (Reference only)
Nominal Voltage: 3.6V
Max charging voltage: 4.2±0.03V
Charging current(Std.) : 0.805A (0~+10°C)/ 1.61A (+10~+45°C)
Charging time(Std.): 4.0 hours Max continuous discharge currnt: 4.83A (0~+40°C)
Discharge end voltage: 2.8V
Internal impedance: (23±2°C) ≤less than 100mΩ
Battery specs;
