Hugh Hemington
With parts trickling in, I now have a Turnigy battery with a red two-barrel shielded "pin and ring" connector, a Zippy battery with what looks like red and black uncircumcised dicks (with shrink tubing foreskins), and a power distribution board with a yellow "arrow" shroud with two pins inside.
I gather there is also something called a "Deans connector" (also called a Tee connector?) that I managed to avoid buying, mainly because I didn't buy FOUR items with power connectors.
First, if there is any way I could have more thoroughly screwed the "power pooch", be sure and rub that in.
Then, let's just say, for the sake of argument I wanted to avoid hopeless madness and decided to standardize all this stuff. What is THE preferred connector to use for ALL batteries and the distribution board? And if there is a technical reason why, WHY?
If there is no known technical advantage to any of them, what are YOU using and are you happy with it? And ease of soldering isn't a factor. I friggin' LOVE soldering.
