Weird!!!
Discussion in 'Build & Tune' started by Garyp, Nov 2, 2016.
  1. Garyp
    Garyp Member
    have a syma x8g quad in which I had to replace both upper and lower body on. I thought I was pretty sure I transferred everything over from the old one to the new one in the same order as I took them off of the old new. After I got it put together I noticed that once it lifted off that the thing restated while it was in flight. Did I overlook anything?
  2. Jackson
    Check to make sure the little antenna on the main board is properly attached and not smashed or crimped.
  3. Garyp
    Garyp Member
    OK I just took it apart again check the antenna it's straight not bent so I put it back together turned it on and what it's doing is when you give it throttle it goes up-and-down fine and you can control it but the drone itself sits and just completely spent and 360° what's up with that
  4. Jackson
    Double check motor rotation and prop placement.
    [​IMG]
  5. Garyp
    Garyp Member
    I just got done checking them and everything checks out just as you say it should be in you're drawing. Here's the thing, I can set it on the table, give it a little throttle and it sits there fine... I go to pick it up and the thing acts like there's a short in it like the motors are alternating back and fourth every
  6. Garyp
    Garyp Member
    Here's a link to what it's doing.
  7. RENOV8R
    It's supposed to do that. What you're seeing is the motors compensating for the change in angle. The gyro wants the quad to be level, so when you tilt it, its thrusting the motors on the low side to try and get it back to level. In fact, it appears to be functioning properly
  8. Garyp
    Garyp Member
    Ok but why does it rotate in circles when it does get airborne?
  9. RENOV8R
    Well, if you transferred every thing over and put the flight control board on wrong, say turned 90 degrees one way or the other (most of us have done this) it would result in what yours is doing
  10. Jackson
    Did you double check the props and rotation per my pic? Well?
  11. Garyp
    Garyp Member
    Yes I did.
  12. Garyp
    Garyp Member
    Does it really matter on which way it's facing, going by if the camera is facing toward the red arrow?
  13. Garyp
    Garyp Member
  14. RENOV8R
    Yes
  15. Garyp
    Garyp Member
    So I need to make sure the camera is facing the direction the red arrow is the go by you're rotation according to the diagram?
  16. DuaneM
    DuaneM Drone? I don't see any drone ... crap!
    Boy I wish I had seen that photo of the blade directions earlier ...
  17. Hi, Sounds like you're in headless mode.. There's acro mode, level mode and headless mode, headless mode will fly in the direction you send it but it will not have a front or back.. Ken
  18. Jackson
    No there isn't.
  19. There won't be acro on this kind of drone, I was just listing the types of modes for his research, amigo..
  20. DuaneM
    Does anyone know how to turn off the crash mode?
